Michael_Sproul1
Apr 23, 2014iRule for HTTPS pool assignment
I have iRules for an HTTP: server like
when HTTP_REQUEST { switch -glob [HTTP::uri] { "thegreen.domain" {pool thegreen_pool } default {pool ecmtstweb1_2_pool } } }
Works fine. Looking for the equivalent for an HTTPS: server.
- Cory_50405
Noctilucent
You can use the same iRule, but you'll need to terminate the SSL on the BIG-IP. You can accomplish this by loading a certificate/key pair for the server that you are proxying for, apply that certificate/key pair to a client SSL profile, and then apply that client SSL profile to your virtual server.
- Michael_Sproul1
OK. Do you know how I can import the SSL certificate from the physical servers for this? Or, do I need to generate a new one for the LTM? - Cory_50405
Noctilucent
If the server administrator can provide you the cert and private key, you can go to Local Traffic -> SSL Certificate List and then click Import. If you have the individual certificate and key files, you can do it by using 'Create' instead of 'Import' - Michael_Sproul1
Thank you!
