irule for choosing pool and rewriting
Hi experts,
I need to write an irule for the following rewriting task.
http://host.domain.tld/example1/appname >> http://[example1_pool]/appname
http://host.domain.tld/example2/appname >> http://[example2_pool]/appname
http://host.domain.tld/example3/appname >> http://[example3_pool]/appname
So depending on the uri I want to choose the pool and also remove the portion between the first and second slash ("/example1").
The application listens on http://[backend_pool]/appname
The following irule does not do the job yet. Do I have to rewrite the answer also on event HTTP_RESONSE? Do I have to use the "STREAM" command?
Any help is appreciated! Regards, Alexander
switch -glob -- [string tolower [HTTP::uri]] {
"/example1" {
redirect
HTTP::redirect http://[HTTP::host]/example1/appname
"/example1/*" {
HTTP::uri [string map {"/example1" ""} [HTTP::uri]]
pool APPNAME_POOL_example1
default {
This final section takes all traffic that has not otherwise
been accounted for
pool wwwserver_pool
- Arnaud_Lemaire
Employee
Hi Alexander, do you think that ltm rewrite profile could be easier for you ? it is available starting 11.4 and can do this rewriting from gui. With ltm policy, you could do the pool selection as well from the gui.
- Jason_40733
Cirrocumulus
I recommend doing a TCPDUMP of the traffic in both directions. If your response does not have the "/example1/*" in the uri when it replies then you could be getting redirected to the wwwserver_pool.
Jason
- Vijay_E
Cirrus
when HTTP_REQUEST { set HOST [string tolower [HTTP::host]] set HOST [string tolower [HTTP::uri]] if { ($HOST eq "host.domain.tld") and ($URI eq "/example1/appname")} { HTTP::uri [string map {"/example1" ""} [HTTP::uri]] HTTP::host [string map {"host.domain.tld" "example1_pool"} [HTTP::host]] pool APPNAME_POOL_example1 } }You would have to run some curl commands to figure out the response from the servers and possibly make changes to the response headers.
- Alexander_01_13
Hi Odaah,
the code you provided does not rewrite the html response. So the first html page is loaded but the links to graphics etc. are broken.
How can I change the response headers? The commands do not work similarly: 01070151:3: Rule [/projects/host.domain.tld_rewrite_irule] error: /projects/host.domain.tld_rewrite_irule:11: error: [command is not valid in current event context (HTTP_RESPONSE)][HTTP::host]
Regards, Alex
- nitass
Employee
this is just an example. it may not fully be what you are looking for but hope it helps.
configuration root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.24.10:80 ip-protocol tcp mask 255.255.255.255 pool foo profiles { http { } stream { } tcp { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } vs-index 3 } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 200.200.200.101:80 { address 200.200.200.101 } } } root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux ltm rule qux { when HTTP_REQUEST { STREAM::disable HTTP::header remove "Accept-Encoding" switch -glob -- [HTTP::uri] { "/example1/*" { HTTP::uri [string map {"/example1" ""} [HTTP::uri]] HTTP::host "example1.domain.tld" } default { do something } } } when HTTP_RESPONSE { if { [HTTP::header value Content-Type] contains "text" } { STREAM::expression {@http://example1.domain.tld@http://host.domain.tld/example1@@http://example2.domain.tld@http://host.domain.tld/example2@} STREAM::enable } } } original response [root@ve11a:Active:In Sync] config curl http://200.200.200.101/test.html 1:http://www.google.com 2:http://example1.domain.tld/something 3:http://example2.domain.tld/somethingelse 4:http://www.yahoo.com trace [root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 80 New TCP connection 1: 172.28.24.1(38472) <-> 172.28.24.10(80) 1415022550.4740 (0.0014) C>S --------------------------------------------------------------- GET /example1/test.html HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: 172.28.24.10 Accept: */* --------------------------------------------------------------- New TCP connection 2: 200.200.200.14(38472) <-> 200.200.200.101(80) 1415022550.4755 (0.0013) C>S --------------------------------------------------------------- GET /test.html HTTP/1.1 User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 Host: example1.domain.tld Accept: */* --------------------------------------------------------------- 1415022550.4778 (0.0022) S>C --------------------------------------------------------------- HTTP/1.1 200 OK Date: Mon, 03 Nov 2014 13:34:43 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Mon, 03 Nov 2014 12:57:04 GMT ETag: "418999-81-e21e2800" Accept-Ranges: bytes Content-Length: 129 Content-Type: text/html; charset=UTF-8 1:http://www.google.com 2:http://example1.domain.tld/something 3:http://example2.domain.tld/somethingelse 4:http://www.yahoo.com --------------------------------------------------------------- 1415022550.4781 (0.0041) S>C --------------------------------------------------------------- HTTP/1.1 200 OK Date: Mon, 03 Nov 2014 13:34:43 GMT Server: Apache/2.2.3 (CentOS) Last-Modified: Mon, 03 Nov 2014 12:57:04 GMT ETag: "418999-81-e21e2800" Accept-Ranges: bytes Content-Type: text/html; charset=UTF-8 Transfer-Encoding: chunked 8b 1:http://www.google.com 2:http://host.domain.tld/example1/something 3:http://host.domain.tld/example2/somethingelse 4:http://www.yahoo.com --------------------------------------------------------------- - Alexander_01_13
I would like to share the solution we have finally found. We changed the rewriting task to a redirecting task. We do the following redirects:
>> >> >>For each exampleX we create a DNS entry and in the irule we switch the pool by the hostname. For encryption we get a wildcard certificate, which does not impose much of a security concern, because the domain.tld is used exclusively for this virtual server.
Thanks to all for helping!
Regards, Alex
