tidenz_92110
Jun 15, 2010irule data class reference issues 9.4.x to 10.1
Hi Guys,
We recently have migrated to v10.1 from 9.4.7 and we have broken our existing irule. The part that is braking is parsing the data class into an array for processing.
when debugging i see that the data class name is added into the array not the actual index and value.
reading through the new class commands in v10.x i need to remove the $::data group as this what is causing the name of the data group to be entered.
I have changed it but i still see the same output in the debug string.
log local0.debug "Adding $index --> $data"
Jun 16 15:51:14 Rule EP-cms-nz-http-ir : Adding URL_REWRITE_NZ_LIST -->
Any ideas?
when RULE_INIT {
set this to 1 to enable maintenance
set ::MAINTENANCE 0
array unset ::ARRAY_REWRITE_NZ
array set ::ARRAY_REWRITE_NZ { }
array unset ::ARRAY_REDIRECT_NZ
array set ::ARRAY_REDIRECT_NZ { }
set ::SERIAL1 0
set ::SERIAL2 0
set ::REQ_COUNT 0
log local0.debug "-------- RULE INIT -------------"
if { [findclass "serial" $::URL_REWRITE_NZ_LIST "|"] != $::SERIAL1 }{
clear contents of previous mem resident table
set ::SERIAL1 [findclass "serial" $::URL_REWRITE_NZ_LIST "|"]
log local0.debug "RELOADING UPDATED URI REWITE CLASS TO MEMORY"
foreach item $::URL_REWRITE_NZ_LIST {
set index [findstr $item "" 0 "|"]
set data [findstr $item "|" 1 "\n"]
set LIST "$index $data"
set ::ARRAY_REWRITE_NZ($index) $data
- hoolio
In 10.x, you can no longer directly access a datagroup as a TCL list. For the same functionality, you can use [class get my_class]:when RULE_INIT { set this to 1 to enable maintenance set ::MAINTENANCE 0 array unset ::ARRAY_REWRITE_NZ array set ::ARRAY_REWRITE_NZ { } array unset ::ARRAY_REDIRECT_NZ array set ::ARRAY_REDIRECT_NZ { } set ::SERIAL1 0 set ::SERIAL2 0 set ::REQ_COUNT 0 log local0.debug "-------- RULE INIT -------------" if { [findclass "serial" URL_REWRITE_NZ_LIST "|"] != $::SERIAL1 }{ clear contents of previous mem resident table array unset ::ARRAY_REWRITE_NZ set ::SERIAL1 [findclass "serial" URL_REWRITE_NZ_LIST "|"] log local0.debug "RELOADING UPDATED URI REWITE CLASS TO MEMORY" foreach item [class get URL_REWRITE_NZ_LIST] { set index [findstr $item "" 0 "|"] set data [findstr $item "|" 1 "\n"] set LIST "$index $data" set ::ARRAY_REWRITE_NZ($index) $data log local0.debug "Adding $index --> $data" } } }
Aaron - tidenz_92110
Thanks Aaron,
I have also made a few changes as the set data [findstr $item "|" 1 "\n"] also inserted a {} bracket.
I have changed the code to set data [findstr $item "|" 1 "\{"] to fix the added backet issue. - tidenz_92110
The initial irule was developed by someone else and uses arrays to store and process redirects, is this the best approach? in terms of speed and future compatibility.
The data class is also defined in the bigip.conf at the moment, the amount of redirects are small(100-200) would it be better to reference them out of external files?
Are there any best practise doc's around data group classes - hoolio
You can use lindex to get the first list element instead of stripping the {}'s:
set data [lindex [findstr $item "|" 1 "\n"] 0]
The CMP compatibility page lists some suggestions for accessing classes in recent LTM versions:
http://devcentral.f5.com/Wiki/default.aspx/iRules/cmpcompatibility
The class command provides additional info on new ways to search datagroups:
http://devcentral.f5.com/Wiki/default.aspx/iRules/class
I'm not aware of any performance benefit of using an external file as a source for a datagroup. Either way the datagroup contents are read from disk to memory upon config load.
Aaron
