Fawad_29089
Jun 04, 2013irule based on source ip not working..plz help!
I am running LTM v 11.1. I am defining irule based on source IP address to select a specific pool. I am getting some syntax and not supported command like error messages for the first few lines. The error message is probably for the class i created. Can somebody help with this!
class ip_subnets_class {
network 120.36.32.0 mask 255.255.240.0
network 172.20.0.0 mask 255.255.0.0
network 172.31.0.0 mask 255.255.0.0
network 149.2.0.0 mask 255.255.0.0
network 149.237.0.0 mask 255.255.0.0
if { [matchclass [IP::client_addr] contains ip_subnets_class }
{ pool VDI_TEST_pool
} else { pool VDI_TEST_POOL_INT}
- hoolio
Can you try this and reply back with the specific error messages you see when trying to save the iRule?
Aaronwhen CLIENT_ACCEPTED { if { [class match [IP::client_addr] equals ip_subnets_class] }{ pool VDI_TEST_pool } else { pool VDI_TEST_POOL_INT } } - richard_77048
matchclass has been deprecated as of v10. You should use the class command instead. See https://devcentral.f5.com/wiki/irules.class.ashx .
You rule would look like this:when HTTP_REQUEST { if { [class match [IP::client_addr] equals ip_subnets_class } { pool VCI_TEST_pool } else { pool VDI_TEST_POOL_INT } } - Fawad_29089
I tried what you suggest with class and got following message :
01070151:3: Rule [/Common/VDI_TEST_REDIRECT] error:
line 1: [command is not valid in the current scope] [class ip_subnets_class {
network 36.36.32.0 mask 255.255.240.0
network 18.2.0.0 mask 255.255.0.0
network 18.237.0.0 mask 255.255.0.0
}] - Fawad_29089
}] - hoolio
The data group should be defined separately in the GUI under Local Traffic | iRules | Data group tab.
I also edited the iRule in my first post slightly. Can you try that once you have the data group created?
Aaron - Fawad_29089
Finally I was able to do it using data group. So the class map for defining IP addresses does not work. Thanks hoolio and all for helping me out!
