kaguras_48797's avatar
kaguras_48797
Apr 18, 2011
iRule and Operators Help
Hi all,
I'a new user and I would like to know is it possible to write an iRule that contorls IP address and cookie which will reject or send a reset package if IP address is not an IP Address that I expecting traffic from and contains some "CookieName" ?
Thanx in advanced
Burcin
  • Yes. That is possible with iRules.
    Here is the Wiki Entry to check on a Cookie:
    http://devcentral.f5.com/wiki/default.aspx/iRules/HTTP__cookie.html
    Here is the Wiki Entry for "class match" (I would suggest using a Data Group unless you know that your only going to want to block a single IP or subnet. Data Groups give you additional flexibility, but if it doesn't fit there are alternatives).
    http://devcentral.f5.com/wiki/default.aspx/iRules/class.html
    If you need additional help in starting your iRule let us know.
  • Hi,
    Thank you very much for your response, I wrote something but it is not working actually, what can be the problem ?
    I'm trying to search some string in GET request and Check one IP, if they dont match, it will not allow the traffic, reject/reset the packet.
    if { [string tolower [HTTP::header "HeaderName"]] contains "Some_String_in_Header" } and ![IP::addr [IP::client_add] equals A.B.C.D]
    {discard }
    Thank you
  • hoolio's avatar
    hoolio
    Add an "r" to IP::client_add so it's:
    if { [string tolower [HTTP::header "HeaderName"]] contains "some_string_in_header" and ![IP::addr [IP::client_addr] equals A.B.C.D]}{
    discard
    Also make sure that the string in your iRule is in lower case as you're setting the HTTP header to lower case.
    Aaron
  • Hello,
    Thank you for information, I ll try tomorrow and see if it works or not, by the way, is there any way to search string as In-sensitive way ?
    Regards
    Burcin
  • It really depends on what command you are using. There are several commands that have a -nocase option, but in some cases it can only be used in certain circumstances. Here are a couple of examples you can look at:
    Class Command -
    String Command -
    http://www.tcl.tk/man/tcl8.4/TclCmd/string.htm
    For the most part you will probably end up using the "string tolower" so that you can set what you are going to process to a known state like hoolio showed.
    Hope this helps.
