masciarellis_32's avatar
masciarellis_32
Jul 28, 2017
iQuery not Returning VIP data from LTM
I have a GTM (12.0.0) and an LTM (12.0.0) setup and have gone through the steps to set up communication between them using bigip_add. When I run a iqdump on the GTM, I see "server" data and "getconfig_element" data being returned but not "vip" data. I run tcpdump on the LTM and I see iquery communications coming in and going out of the LTM. Based on this, I assume the trust is set up correctly.
The LTM has a "Green" status and I can go directly to it and reach my web server. Problem is, the GTM shows the LTM object as "Red" and will not return the IP address. We verified the LTM object defined in the GMT has the correct IP address and port number.
Has anyone seen this before?
  • Hello,
    You need a server and client extension for your certificates.
    Once that is done then you need to import those signed certs to your LTM and GTM. It goes to two places in GTM one under the System > Device Certificate and another under GSLB > Servers > Trusted Server Certificates. Hope this will resolve the issue.
    Thanks, Pankaj
