Tiaan_92076
Feb 18, 2010Interface Failover Script via Monitor
I wrote the following script to failover between interfaces in environments where STP or 802.3ad is not available. Eg, when using Cisco's PVST or LACP not supported when cables terminate in separate switches.
I haven't fully tested the script.
!/bin/bash
This script is a F5 external monitor to failover the NICs in case of a cable or switch problem.
Using a spanning tree protocol or 802.3ad would be the preferred method of NIC redundancy. If
these protocols is not supported in the environment this script can be used.
The script expects the two interfaces to provide redundancy on as input parameters, eg. 1.1 1.2
Last updated 18/02/2010
Check if 4 parameters were passed to the script
if [ "$" != "4" ]; then
logger -p local0.warning "Interface Failover: Only supply two interfaces"
exit 1
fi
Check if there is already a copy of the monitor running, monitors will fire on the specified interval regardless if it's still running
It sometimes takes a couple of seconds for the interface to come up, this check will prevenet a flip flop between the two NICs
if pgrep int_fail > /dev/null; then
logger -p local0.warning "Interface Failover: Script already running, aborting"
exit 1
fi
Ignore the 2 default parameters passed by the monitor
shift
shift
Setup variables
interfaces="$*"
state="false"
state2="false"
state3="false"
Output interface status to temporary file
b interface all show all | grep INTERFACE > /tmp/b_interface_show
Read statuses from above command into variables
int1_status=`grep "^INTERFACE *$1 " /tmp/b_interface_show | awk '{print $5}' | tr '[:lower:]' '[:upper:]'`
int1_config=`grep "^INTERFACE *$1 " /tmp/b_interface_show | awk '{print $4}'`
int2_status=`grep "^INTERFACE *$2 " /tmp/b_interface_show | awk '{print $5}' | tr '[:lower:]' '[:upper:]'`
int2_config=`grep "^INTERFACE *$2 " /tmp/b_interface_show | awk '{print $4}'`
Check if both interfaces ae enabled, this will cause a loop on the network
if [ "$int1_config" == "ENABLED" ] && [ "$int2_config" == "ENABLED" ]; then
logger -p local0.warning "Interface Failover: ERROR: Only one interface should be enabled"
exit 1
fi
Check if interface 1 is down and enabled and interface 2 disabled; if this is the case a failover need to happen
if [ "$int1_status" == "DOWN" ] && [ "$int1_config" == "ENABLED" ] && [ "$int2_config" == "DISABLED" ]; then
logger -p local0.warning "Interface Failover: Interface $1 is $int1_config and $int1_status"
logger -p local0.warning "Interface Failover: Disabling interface $1"
Disable interface 1
b interface $1 disable
Loop for 5 seconds or until interface 1 is disabled
for i in {1..5}
do
Output interface 1 status to temporary file
b interface $1 show all | grep INTERFACE > /tmp/b_interface_$1_show
Read status from above command into variable
config=`grep "^INTERFACE *$1 " /tmp/b_interface_$1_show | awk '{print $4}'`
Check if interface 1 is disabled
if [ "$config" == "DISABLED" ]; then
logger -p local0.warning "Interface Failover: Enabling interface $2"
state3="true"
Enable interface 2 after confirming interface 1 is down
b interface $2 enable
break
fi
sleep 1s
done
If the interface was not enabled in 5 seconds abort the script
if ["$state3" == "false"]; then
logger -p local0.warning "Interface Failover: Error: Unable to disable interface $1"
exit 1
fi
Loop for 5 seconds or until interface 2 is enabled
for i in {1..5}
do
Output interface 2 status to temporary file
b interface $2 show all | grep INTERFACE > /tmp/b_interface_$2_show
config=`grep "^INTERFACE *$2 " /tmp/b_interface_$2_show | awk '{print $4}'`
Check if interface 2 is enabled
if [ "$config" == "ENABLED" ]; then
logger -p local0.warning "Interface Failover: Interface $2 enabled"
state="true"
break
fi
sleep 1s
done
if ["$state" == "false"]; then
logger -p local0.warning "Interface Failover: Error: Unable to enable interface $2"
exit 1
fi
Waiting for 30 seconds for the interface to come up
for i in {1..30}
do
status=`grep "^INTERFACE *$2 " /tmp/b_interface_$2_show | awk '{print $5}' | tr '[:lower:]' '[:upper:]'`
Check if interface 2 is up
if [ "$status" == "UP" ]; then
logger -p local0.warning "Interface Failover: Interface $2 UP"
state2="true"
break
fi
sleep 1s
done
If the interface did not come up in 30 seconds abort the script
if ["$state2" == "false"]; then
logger -p local0.warning "Interface Failover: Error: Interface $2 not coming UP"
exit 1
fi
fi
Check if interface 2 is down and enabled and interface 1 disabled; if this is the case a failover need to happen
if [ "$int2_status" == "DOWN" ] && [ "$int2_config" == "ENABLED" ] && [ "$int1_config" == "DISABLED" ]; then
logger -p local0.warning "Interface Failover: Interface $2 is $int2_config and $int2_status"
logger -p local0.warning "Interface Failover: Disabling interface $2"
b interface $2 disable
for i in {1..5}
do
Check if interface 2 is disabled
logger -p local0.warning "Interface Failover: Enabling interface $1"
state3="true"
Enable interface 1 after confirming interface 2 is down
b interface $1 enable
break
fi
sleep 1s
done
logger -p local0.warning "Interface Failover: Error: Unable to disable interface $2"
exit 1
fi
Loop for 5 seconds or until interface 1 is enabled
for i in {1..5}
do
Check if interface 1 is enabled
logger -p local0.warning "Interface Failover: Interface $1 enabled"
state="true"
break
fi
sleep 1s
done
logger -p local0.warning "Interface Failover: Error: Unable to enable interface $1"
exit 1
fi
for i in {1..30}
do
status=`grep "^INTERFACE *$1 " /tmp/b_interface_$1_show | awk '{print $5}' | tr '[:lower:]' '[:upper:]'`
Check if interface 1 is up
logger -p local0.warning "Interface Failover: Interface $1 UP"
state2="true"
break
fi
sleep 1s
done
logger -p local0.warning "Interface Failover: Error: Interface $1 not coming UP"
exit 1
fi
fi
Remove temporary files
rm /tmp/b_interface_$1_show
rm /tmp/b_interface_$2_show
rm /tmp/b_interface_show
Monitor expects output of "up"; no return value will mark the monitor down
echo "up"
exit 0
Tiaan
- Tiaan_92076
It seems like a monitor still running when the next interval is reached; is killed and a new monitor started. Is there any way to prevent this ? - spark_86682Historic F5 AccountThere is no way to prevent the kill signal from being sent. If you really need that, then have your EAV spawn a new process in a new process group, so that child will not receive the signal. It's a bit tricky because the original process will still need to be around to talk to bigd, but it can be done.
- gnk_32170
hello, is it possible to take this script in a monitor and execute it ?
I execute this script in a monitor with the command b monitor interface_failsafe run and nothing happend whereas in execute it with the command sh /usr/bin/monitors/interface_failsafe.eav 0 0 1.1 1.2 its works.
Can you help me ? - Tiaan_92076
Hi, I'm using it in a monitor currently, try renaming the file to "interface_failover", removing the extension. - gnk_32170
Hello, its not work without the extension. I'm using a little script who create a file in tmp like : echo test > /tmp/test.log.
In run it in shell, its work and in external monitor with b monitor test run, it doesn't create the file.
I think that there is an communication error in processes when i run the monitor.
