sosabsd_111766
Feb 15, 2009Interface 0.1: soft resetting due to transmitter failure.
Hi
i get following message in LTM log what does it mean and howto fix it.
LTM logs
Feb 15 21:43:11 tmm tmm[735]: 01230112:2: Interface 0.1: soft resetting due to transmitter failure.
Feb 15 21:43:11 tmm tmm[735]: 01230002:4: Interface 0.1: link is down
[root@ecds:Active] snoops b version
Kernel:
Linux 2.4.21-9.1.2.37.0smp
Package:
BIG-IP Version 9.1.2 40.2
Final Edition
Enabled Features:
VLAN Groups Spanning Tree Protocol
Interface Mirroring Basic Load Balancing
Transparent Device Load Balancing Round Robin Load Balancing
Ratio Load Balancing Least Connection Load Balancing
Fastest Load Balancing Predictive Load Balancing
Observed Load Balancing Priority Load Balancing
Dynamic Ratio Load Balancing Last Hop Pool
Route Pool VLAN Failsafe
Pool Min Up Members Failover
Active Active State Mirroring
ICMP Monitor gateway ICMP Monitor
TCP Echo Monitor TCP Monitor
HTTP Monitor HTTPS Monitor
FTP Monitor Transparent Device Monitor
Reverse Keyword SMTP Monitor
POP3 Monitor NNTP Monitor
LDAP Monitor IMAP Monitor
RADIUS Monitor LDAP Over SSL Monitor
Oracle Monitor Soap Monitor
Microsoft SQL Monitor EAV Monitor
WMI Monitor SNMP Monitor
RealN Monitor TCP Half Open Monitor
UDP Monitor SIP Monitor
SCRIPTED Monitor WAP Monitor
Monitor Rules L4 iRules
L7 iRules HTTP Header Transformation
HTTP Content Transformation HTTP Redirection
Probe Control - IDS Traffic Management Connection Limits
Connection Rebinding OneConnect - Switching and Pooling
SNAT Standard iSNAT - Rules Referencing SNAT Pools
Simple Persistence Sticky Persistence
SSL Session ID Persistence Cookie Persistence
SIP Persistence WTS Persistence
Universal Persistence QoS and ToS Tagging
Packet Filter SSL Support
SSL Support for LDAP Authentication SSL Mbps 4000
SSL Total TPS 100 PVA Enable
[root@ecds:Active] snoops b interface
interface speed pkts pkts pkts pkts bits bits errors trunk
Mb/s in out drop coll in out
mgmt DN 100 FD 1394 963 0 0 1.163M 6.773M 0
1.1 UP 1000 FD 82.72M 19.86M 0 0 407.2G 96.78G 0
1.2 UP 100 HD 126 0 317 0 556160 0 0
1.3 DN 1000 FD 0 0 0 0 0 0 0
1.4 DN 1000 FD 0 0 0 0 0 0 0
1.5 DN 1000 FD 0 0 0 0 0 0 0
1.6 DN 1000 FD 0 0 0 0 0 0 0
1.7 DN 1000 FD 0 0 0 0 0 0 0
1.8 DN 1000 FD 0 0 0 0 0 0 0
1.9 DN 1000 FD 0 0 0 0 0 0 0
1.10 UP 100 HD 254367 354147 2 0 144.7M 704.8M 0
1.11 DN 1000 FD 0 0 0 0 0 0 0
1.12 DN 1000 FD 0 0 0 0 0 0 0
1.13 DN 1000 FD 0 0 0 0 0 0 0
1.14 DN 1000 FD 0 0 0 0 0 0 0
1.15 DN 1000 FD 0 0 0 0 0 0 0
1.16 DN 1000 FD 0 0 0 0 0 0 0
2.1 UP 1000 FD 19.99M 82.84M 180 0 97.57G 409.8G 0
2.2 MS 1000 FD 0 0 0 0 0 0 0
2.3 MS 1000 FD 0 0 0 0 0 0 0
2.4 MS 1000 FD 0 0 0 0 0 0 0
- The_Bhattman
From what I understand this should have been fixed in the version you are running. You will want to call F5 support to see if they have a CR tracking this or a patch.
