Intercepting crossdomain.xml requests irule works with HTTP but not with HTTPS - please help
Hi
I made an iRule to intercept flash client requests for the crossdomain.xml file, and masked it with another xml. This all works fine with HTTP request, but when trying to add the iRule to another virtual server using HTTPS and SSL offloading i get the following:
01070394:3: HTTP_REQUEST event in rule (faceme_set_crossdomain) requires an associated HTTP or FASTHTTP profile on the virtual server (vs_dev_faceme_rtmp).
I'm a bit of a newb so please be gentle, but any help would be appreciated.
I also tried, setting an HTTP Profile in the virtual server but, client requests seemed to fall into a hole.
- What_Lies_Bene1
Hey Steve. There's no reason the iRule shouldn't work on a SSL terminating standard Virtual Server. Two questions;
1) Are there other iRules assigned to the SSL VS?
2) Could you post the VS configuration from the CLI: tmsh list ltm virtual 'name' - Steve_Kelly_126
Thanks Steve for your quick reply, there are no other iRules assigned to the SSL VS, and here's the VS info:
ltm virtual vs_dev_faceme_rtmp {
destination 123.100.113.198:https
ip-protocol tcp
mask 255.255.255.255
pool dev_rtmp
profiles {
dev_stream1_ssl {
context clientside
tcp { }
- nitass
Employee
i do not think http profile is applicable.
Real Time Messaging Protocol
http://en.wikipedia.org/wiki/Real_Time_Messaging_Protocol - What_Lies_Bene1
Is the Virtual handling RTMP traffic rather than HTTP? - Steve_Kelly_126
Hi Yeah the rtmp session is wrapped in an ssl session actually. We are using the rtmps protocol. - What_Lies_Bene1
OK, in which case you'll not be able to use HTTP related events. Perhaps you can post the code (suitably secured) and we can find a different way? - Steve_Kelly_126
Here's the iRule (no problem with it being unsecured):
log local0.info "GOT REQUEST"
set crossdomain {
if { [HTTP::path] equals "/crossdomain.xml"} {
log local0.info "CAUGHT CROSSDOMAIN REQUEST"
HTTP::respond 200 content $crossdomain
HTTP::release
log local0.info "MOVING ON"
return
} - What_Lies_Bene1
OK, so as I said, we can't use the HTTP events. Would you be able to do a tcpdump to see what the request for this resource actually looks like please? We could then probably search for it and use TCP::respond to send the response. Shame there's no built in support for RTMP.
