henrykay_123_28's avatar
henrykay_123_28
Oct 03, 2016
intercept response and modify http:// to https://
hi guys,
i am currently implementing SAP with F5, however we ran into 1 issue. The SAP is configured to only support http so SSL offload was done on F5. i have 2 VS. one 443 and 1 80
the issue we run into is that a couple of the functionalities in SAP does a POST action to the http://url during the post, certain information such as emp_id are sent together. but however when the traffic hits the port 80 VS, the information went missing and the requested POST action can't be completed.
i have tried the following to change the http to https in the response but seems like it is still hitting the port 80 vs
STREAM::disable
when HTTP_RESPONSE {
        STREAM::expression "@http://@https@://"
        STREAM::enable
seems like even if i dont put any condition, it hits the response irule but after that it still goes to the port 80 VS
Would anyone be able to point me to the right direction or information to resolve this?
  • THi's avatar
    THi
    Is the stream expression as you stated above? The third delimiting @-sign should be in the end. Now you are replacing " with "https".
    Instead of:
    Try:
    STREAM::expression "@http://@https://@"
  • hi henrykay, you can try irule shown below;
    HTTP::header remove Accept-Encoding
    STREAM::disable
    if { [HTTP::header exists Location] } {
        HTTP::header replace Location [string map {"http://" "https://"} [HTTP::header Location]]
    if { [HTTP::header Content-Type] contains "text" } {
        STREAM::expression {@http://@https://@}
        STREAM::enable
  • oops. thats a typo on my portion. what i entered is the one that you have suggested.
