Anuj_Chaudhary_'s avatar
Anuj_Chaudhary_
Dec 14, 2016
Installation of F5 Devices
Hi Guys,
As of now we are having Radware LB and thinking to buy F5.
So what will be best mode to deploy(Active/Active or Active/Standby) F5s and why ?
How we can implement that devices.
regards, Anuj
  • It does depend on your detailed requirements and system load. But overall I would recommend to go the Active/Active approach since its somewhat easy to implement.
    The benefit of this approach is a slightly reduced latency then, since under normal conditions the load is shared between the individual units and will therefor result in more "idle" time to pickup new connection/request.
    But keep in mind that you don't overbook the individual units, so that in the case of a system failure a single unit will be able to handle the entire load.
    If you're running an F5 environment with 3 units, then Active/Active/Standby will be ideal. In this case the third unit can be configured as hot-standby for both Active units. In this case you can book the Active units up to 100% load without getting problems if a failover (single device failure) ocours.
    Cheers, Kai
