James_Flood_401
Mar 06, 2007Installation Issue
I apologize if this is in another post, I couldn't find it.
After running the setup the splash page comes up but then followed by another pop up stating "Incomplete Installation."
The text in the pop up is "Cannot locate iRuler.xml configuration file". Though I'm not so sure the editor is actually getting installed, I'd assume it installs in Program Files? No F5 reference there. When clicking on the Start Menu Program group I get the same pop-up/text combo.
Any ideas. One caveat is that I "did" have .net3.0 installed but ripped it off after the first hour of banging my head on my desk!
Thanks for the help.
- That's for the feedback. I'll test the install out tomorrow and see what's up.
-Joe - Oops on my part... Looks like when I refactored the install for the new release, I forgot to embed the iRuler.xml file as an embedded resource in the executable. The setup file has been updated so please re-download it and rerun the setup.
Sorry about the inconvenience.
-Joe - James_Flood_401
Yup I'm good now. Thank you!
