Insert X-Frame-Options header when specific URI is not used
I am having a tricky time getting an iRule to match criteria. I am trying to get the X-Frame-Options SAMEORIGIN header inserted whenever a URI does NOT match a specific string.
Here is the rule I have so far:
when HTTP_RESPONSE {
if { ($hostLowered eq "domain.example.edu") and !($uriLowered contains "/sites/prod") } {
HTTP::header insert "X-Frame-Options" "SAMEORIGIN"
log local0. "Success: $hostLowered $uriLowered [IP::client_addr]"
else [ log local0. "Failure: $hostLowered $uriLowered" ]
When I use cURL to test, all of the responses I'm getting back include the X-Frame-Options SAMEORIGIN header. The second log statement is even showing the exact URI that matches the second argument on line 2.
Hi Zuke,
you may try the iRule below to conditional inject the X-Frame-Option header...
when HTTP_REQUEST { if { ( [string tolower [HTTP::host]] eq "domain.example.edu" ) and not ( [string tolower [HTTP::uri]] starts_with "/sites/prod" ) } then { set insert_x_frame_options 1 log local0.debug "[HTTP::host][HTTP::uri] requires x_frame_options" } else { set insert_x_frame_options 0 log local0.debug "[HTTP::host][HTTP::uri] does not require x_frame_options" } } when HTTP_RESPONSE { if { $insert_x_frame_options } then { HTTP::header insert "X-Frame-Options" "SAMEORIGIN" log local0.debug "Injected x_frame_options" } }Cheers, Kai
- Kevin_Nelson
Used Kai's irule as a basis for one we needed. The conditions were a bit different where our determination of if/what value to return was based on the presence and contents of a query string value. In short, the query string value for 'CID' identifies a client for which we needed to respond with different X-Frame-Options header values based on whether they were framing us.
Configure a custom response for the X-Frame-Options header based on the CID in the URI query string. Custom cid-specific settings are pulled from the 'xfo_client_overrides' list where the client cid is the 'string' and the desired X-Frame-Options value the 'value'. Example: 12345678 := DENY when HTTP_REQUEST { set uri [string tolower [HTTP::uri]] set qcid [URI::query $uri cid] set ccid ([HTTP::cookie value "xcid"]) if {[info exists qcid] and $qcid ne ""} { set cid [string trim $qcid "()"] set setcookie 1 } elseif {[info exists ccid] and $ccid ne ""} { set cid [string trim $ccid ")("] } else { set cid 0 } } when HTTP_RESPONSE { if { [ class search xfo_client_overrides equals $cid ] } { HTTP::header replace "X-Frame-Options" [class lookup $cid xfo_client_overrides] } if { [info exist setcookie] } { HTTP::cookie insert name "xcid" value $cid path "/" version 1 HTTP::cookie secure "xcid" enable HTTP::cookie httponly "xcid" enable } }The value that is returned in the header is looked up from a 'xfo_client_overrides' string-based Data Group List. So basically there's a lookup table that matches the CID value (or subsequent xcid cookie value) to the value returned in the X-Frame-Options header.
So for example:
999991 := DENY 999992 := SAMEORIGIN 999993 := ALLOW-FROM https://www.somedomain.comSince in our situation the CID query value goes away after the initial request, I set that value into a 'xcid' cookie so the information persists for the duration of the session. Should a new CID query value come in on the URI, that value would be used and the xcid cookie value updated.
This script does not permit for a default response were the CID not listed in 'xfo_client_overrides' or if the CID were absent altogether. This could be added relatively easily with an
on the firstelse
condition in HTTP_RESPONSE (either be hard-coding in the script or by doing a lookup for a default value configured in 'xfo_client_overrides' as '0' or 'default' as inif
). Haven't thought through the logic on this entirely but the answer is close if not quite right. The advantage to the default value in 'xfo_client_overrides' solution should be that one could choose to have a default or not based on whether one exists in the lookup table (though this would necessitate andefault := SAMEORIGIN
rather than anelseif
I suppose).else
