Randy_Johnson_1's avatar
Randy_Johnson_1
Apr 06, 2010
Insert Header at HTTP_REQUEST_SEND phase ?
Having some trouble with this one -
when HTTP_REQUEST_SEND {
set http_send_time [clock clicks -milliseconds]
HTTP::header insert "X-loadbalancer-timestamp-send" $http_send_time
log local0.info "Client sent these HTTP headers [HTTP::header names]"
This errors with "
Apr 6 15:03:47 tmm tmm[2077]: 01220001:3: TCL error: sendheader
Is this telling me that I can't execute a header insert at the HTTP_REQUEST_SEND phase ?
Thanks, everyone !!!
  • hoolio's avatar
    hoolio
    Try wrapping the HTTP::header commands in the clientside command to force evaluation of the commands into the clientside context. This is necessary as HTTP_REQUEST_SEND is a serverside context event:
       clientside {
    http://devcentral.f5.com/wiki/default.aspx/iRules/http_request_send
    Triggered immediately before an HTTP request is sent to the server-side TCP stack. This is a server-side event. Because of that, if you wish to execute commands in a client-side context in this event, you will need to use the clientside command to do so.
    http://devcentral.f5.com/wiki/default.aspx/iRules/clientside
    Causes the specified iRule commands to be evaluated under the client-side context.
    Aaron
