Ger_Hackett_323's avatar
Ger_Hackett_323
Sep 19, 2012
Increment Array Element
Is there any neat way to increment any array element. At the moment I’m doing:
set TempVar $::MyArray($some_index)
incr TempVar
set ::MyArray($some_index) $TempVar
unset TempVar
Thanks,
Ger.
  • You could potentially one-line it with something like this:
    array set TempVar { var 1 }
    set TempVar [incr TempVar(var)]
    set TempVar(var) [incr TempVar(var)]
  • hoolio's avatar
    hoolio
    Using a global array will disable CMP. You might want to check if using a table will work for your scenario as it's CMP compatible:
    https://devcentral.f5.com/wiki/iRules.CMPCompatibility.ashx
    https://devcentral.f5.com/wiki/iRules.table.ashx
    Aaron
