yuce_sungur_100
Sep 29, 2009inband monitor
I have a virtual server on port 80 and there is a pool attached to it.The monitor for the pool is inband monitor.The nodes in the pool are sending 500 but the inband monitor still don not decla Is there anyone who has inband monitor functioning?
- The_Bhattman
You can enable debug on bigd, the monitoring daemon, by running 'b db bigd.debug enable'. You can disable it by running 'b db bigd.debug disable'. the log output is written to /var/log/bigdlog.
I hope this helps
CB - hoolio
