Inactivity-timeout for tmsh connection
I had set the inactivity-timeout as 30 mins on my LTM (set months before). The tmsh list sys sshd inactivity-timeout returns me the following result.
ssh sshd {
inactivity-timeout 1800
I am expecting that any tmsh session that i establish on to my F5 box will timeout after the idle of 30 mins, but when i executed the w command recently, i see that there are stale connections that are idle for more than the given idle timeout. The output is given below..
[root@dc1autof5ltm01b:Active] config w
22:28:09 up 15 days, 6:37, 25 users, load average: 0.97, 0.76, 0.67
USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT
testserver pts/0 192.168.31.50 20:11 2:16m 0.32s 0.30s tmsh
testserver pts/1 192.168.61.137 Mon11 4days 0.34s 0.32s tmsh
testserver pts/2 192.168.61.137 20:41 1:46m 0.32s 0.30s tmsh
testserver pts/3 192.168.61.137 Tue06 3days 0.32s 0.30s tmsh
testserver pts/4 192.168.61.137 Tue06 3days 0.33s 0.31s tmsh
testserver pts/5 192.168.61.137 Tue11 3days 0.37s 0.36s tmsh
root pts/6 192.168.9.69 22:28 0.00s 0.03s 0.00s w
testserver pts/7 192.168.61.137 Tue18 3days 0.28s 0.26s tmsh
testserver pts/8 192.168.61.137 20:44 1:43m 0.31s 0.29s tmsh
testserver pts/9 192.168.61.137 20:46 1:41m 0.31s 0.30s tmsh
testserver pts/10 192.168.61.137 Tue06 3days 0.30s 0.29s tmsh
testserver pts/11 192.168.61.137 Wed09 2days 0.26s 0.24s tmsh
testserver pts/12 192.168.61.137 Wed09 2days 0.29s 0.27s tmsh
testserver pts/13 192.168.61.137 Wed11 2days 0.28s 0.27s tmsh
testserver pts/14 192.168.61.137 Wed12 2days 0.29s 0.28s tmsh
testserver pts/15 192.168.61.137 11:16 11:11m 0.33s 0.31s tmsh
testserver pts/17 192.168.31.77 17:14 5:13m 0.30s 0.28s tmsh
testserver pts/18 192.168.61.137 Wed16 2days 0.34s 0.33s tmsh
testserver pts/24 192.168.61.137 11:46 10:41m 0.26s 0.24s tmsh
testserver pts/26 192.168.61.137 Wed20 2days 0.34s 0.32s tmsh
testserver pts/32 192.168.61.137 Wed20 2days 0.31s 0.29s tmsh
testserver pts/34 192.168.61.137 13:21 9:06m 0.25s 0.23s tmsh
testserver pts/40 192.168.61.137 Wed20 2days 0.31s 0.29s tmsh
testserver pts/41 192.168.61.137 Thu11 35:11m 0.24s 0.22s tmsh
testserver pts/44 192.168.61.137 13:24 9:03m 0.25s 0.25s tmsh
The timeout happens properly in most of the cases-where my unused sessions get closed off properly, but there are a few sessions like these that are stale.
Am i doing or understanding it wrong, or is it that the F5 box is not acting on the inactive sessions?
- shaggy
I generally set both the sshd and tmsh cli idle-timeouts:
(Active)(/Common)(tmos) modify cli global-settings idle-timeout ? Set the idle timeout value for users in the tmsh command line interface. Time is set in number of minutes or disabled. - Naresh_173597
Shaggy,
Thanks for the reply, but in boxes of tmos version 10.x we don't find idle-timeout util.
Here are some queries.
1)Also is it mandatory to set these options to kick off idle sessions. Ain't those taken care by f5 itself without any manual configuration.
2) If am setting the time-out today will it kill the older sessions as well.
3) Is it advisable to clean the idle sessions with external scripts which looks some thing like this,
netstat -anp | grep | awk '{print $7}' | cut -d \/ -f1 | grep -oE "[[:digit:]]{1,}" | xargs kill
- shaggy
try: tmsh modify sys global-settings console-inactivity-timeout I don't have a v10 to test, but it appears to have worked for someone else in v10 - shaggy
1) If you want session timeout, you should set these values. As far as I know, F5 doesn't have a default CLI/SSH/TMSH/bigpipe timeout. 2) I'm not sure if it will kill the older sessions as I expect the timeout applies to new sessions only. If they remain after making the change, you can use "ps | grep sshd | grep (user-name)" and "kill (pid)" to clear the old sessions 3) This isn't necessary if the timeouts are set and function as expected 3a) If this is an automated process/device logging into the F5, can it be configured to send the appropriate quit/exit commands to properly terminate the session when completed? - theprophet_2612
Just following guide, it can resolve your problem System > Configuration > SSHD. In the Idle Time Before Automatic Logout, adjust duration time you prefer
