Dan_Pacheco's avatar
Nov 17, 2017
In an HA pair, which device sends monitor traffic?
HA pair setup with fast failover, aka ha-group running v12.1.2 hf1. Single traffic group.
I expected both the active and standby LTM devices to send monitor traffic to nodes but when I tcpdump on both devices I see health check traffic sourcing only from the active device. Thinking it was an issue with that ha pair I checked a different ha pair and saw the same thing. So I am looking for confirmation....
Which device sends monitoring traffic, active, standby or both?
  • Both devices should be sending monitors, this is required so that the standby device can go active and start serving traffic.
    Is your configuration synchronised and can you ping/curl the pool members from each device out of the equivalent network?
