David_Gilbert_2's avatar
David_Gilbert_2
14 years ago
Importing SAN certificate issue
Running version 10.1. While trying to import a SAN certificate, I am getting an invalid character message. Any ideas why this is happening? The SAN was exported from IIS (Microsoft Exchange 2010) outlook web app server in pkcs 12 format
  • hoolio's avatar
    hoolio
    Hi David,
    Can you try converting the cert to PEM and then import it? This might be a bug in the PKCS12 logic.
    sol6549: Converting PKCS certificates to PEM format for use with the BIG-IP
    http://support.f5.com/kb/en-us/solutions/public/6000/500/sol6549.html1
    Either way, I'd open a case with F5 Support to check whether it's a bug.
    Aaron
