edmonaft_351139
Mar 12, 2018Implementing HSTS on F5 LTM 12.1.2 HF2 without using iRules
Hi there,
May i ask if is there a way that I could toggle enforcing HSTS under this firmware without resorting to using iRules? If so, may i know how it's done?
Thank you!
- jaikumar_f5
Noctilucent
I read somewhere in article that beginning in v12, its available in the HTTP profile setting itself. You need not go with the Irule, but rather get this done through the HTTP profile itself.
Edit: Please follow the below article.
https://support.f5.com/csp/article/K40243113
HTTP Strict Transport SecurityNote: The HTTP Strict Transport Security (HSTS) settings are only available in BIG-IP 12.0.0 and later. The Preload option is only available starting in BIG-IP 13.0.0 or later.The below article may also give you more info,
