Andrea_Arquint
Dec 21, 2012imap monitor for exchange 2010 iapp failed
Hello
I installed newest Exchange 2010 iAPP template 2012_06_08 on a bigip (with version 11.2.1 HF1).
Everything works fine but imap monitor generated via iapp does not work. The imap service is available via port 143 on each cas server with any imap client software
accessable and I´m able to access the imap port 143 via telnet from the bigip command line as well. So, there must something with the monitor itself.
Are there any exeriences within this case?
thanx bb
- mikeshimkus_111Historic F5 AccountHi bigbrother, we haven't run into any issues with the IMAP monitor in our testing. If you like, you can post a scrubbed version of the monitor config here and we can review it. You should also open a case with F5 support, as it will help us track outstanding issues with the iApp.
thanks
Mike
