Hamada_Tabosha_'s avatar
Hamada_Tabosha_
Oct 13, 2014
images and hot fixes
Dears, Im doing a security assessment for the F5 device, and I found 2 vulnerabilities on my image which is 10.2.4 hf2 as per f5 documents : one of them can be solved by hf3 and the second can be solved by hf4
so if i installed hf3 then installed hf4 over it, will this fix the two vulnerabilities ?
  • Hello Hamza,
    Typically the latest HF will cover roll-up fixes for the previous HF but Its always good to go through the read-me files to ensure that is the case. If your considered a HF upgrade you might want to go with HF5 which covers the bash shell vulnerabilities patches.
    Special engineering hot fixes are not covered in typical new HF releases.
  • Hi Hamza,
    the latest hotfix for your v10 is the Hotfix-BIGIP-10.2.4-855.0-HF9.
    And I would recommend to upgrade to HF9 as there will probably notices about other known vulnerabilities in both HF3 and HF4.
    If your H/W-platform supports it and is under service, I would consider to upgrade to v11.
    A v11 upgrade may require a very careful configuration review due to changed behavior.
    Thanks,
    Stephan
