IllegalArgumentException using iControl assembly 11.2
Error log:
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: org.xml.sax.SAXException
java.lang.IllegalArgumentException
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:org.xml.sax.SAXException
java.lang.IllegalArgumentException at org.apache.axis.encoding.ser.SimpleDeserializer.onEndElement(SimpleDeserializer.java:176) at org.apache.axis.encoding.DeserializerImpl.endElement(DeserializerImpl.java:502) at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1087) at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:171) at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141) at org.apache.axis.message.RPCElement.deserialize(RPCElement.java:345) at org.apache.axis.message.RPCElement.getParams(RPCElement.java:384) at org.apache.axis.client.Call.invoke(Call.java:2467) at org.apache.axis.client.Call.invoke(Call.java:2366)at org.apache.axis.client.Call.invoke(Call.java:1812)at iControl.LocalLBMonitorBindingStub.get_template_list(LocalLBMonitorBindingStub.java:1085)
Axis log:
2012-07-16T18:32:51.015Z DEBUG [xxx@xxx][Serving-127.0.0.1:40136] org.apache.axis.ConfigurationException - Exception: org.apache.axis.ConfigurationException: No service named urn:iControl:LocalLB/Monitor is available
Any ideas?
- That's an odd error. What version of LTM are you attempting to connect to? Can you open the WSDL with a browser:
https://bigip/iControl/iControlPortal.cgi?WSDL=LocalLB.Monitor
Also, could you post your initialization code for your iControl.Interfaces object? The error message stating "Serving-127.0.0.1:40136" doesn't look like you are connecting to an LTM, but rather to localhost.
-Joe - Mariano_57796
Hi Joe,
I work with Ariel and will be also following this issue. Here is the WSDL you asked: http://pastebin.com/QbpB0jfM
The initialization code is this (we don't do much):
Interfaces interfaces = new iCon trol.Interfaces();
interfaces.initialize(, , );
interfaces.getLocalLBMonitor().get_template_list(); // this fails
Regarding the 127.0.0.1 address, that appears because Ariel took the information from one of our logs, and our application was serving an internal client. We connect to a real LTM. Indeed, there are only two methods that fail (the other is LocalLBPool.get_all_member_statistics()), the rest work normally.
Regards.
