mdcarson_58978
Aug 08, 2012If not a , b, or c, do 1 through 15
I have an iRule where I need to run some commands, but only if the URI does not match several cases.
I can't seem to get two negative conditionals to work and I don't have the option to invert the checks and use switch.
This works OK:
if { !([HTTP::uri] starts_with "/blah") }{
do something
This doesn't:
if { ( !([HTTP::uri] starts_with "/blah")) or ( !([HTTP::uri] starts_with "/blah2")) }{
do something
Ideally, l'd like to have a rule that says if the URI doesn't start with any of these five things continue with the rest of the irule.
Any suggestions?
- hoolio
Here's an example:when HTTP_REQUEST { switch -glob [HTTP::uri] { "/a*" - "/d*" - "/f*" { Do nothing } default { Did not match a, d or f so do something } } }
Aaron - mdcarson_58978
Pretty basic. I should have figured that out. I find solutions for my problems in your past forum posts all the time. Thanks for your help Aaron!
