rm-clsnetwork_3's avatar
rm-clsnetwork_3
Nov 05, 2018
Solved
ICAP max L3 hops?
Hi All,
Is there a recommended limit on L3 hops to your icap server for AV protection so as not to cause latency?
Cheers,
Matt
  • How many hops you have now ? And what are the ICMP responses for each hop ?
  • g-ram's avatar
    g-ram
    • rm-clsnetwork_3's avatar
      rm-clsnetwork_3
      We are currently installing our first F5 cluster and are planning based on best practice and wanted to know if there was a best practice when it came to ICAP. The design provided to us by the architects is currently four hops and three of them are firewalls.
    • g-ram's avatar
      g-ram
      Typically I dont see a performance degrade with icap protocol though we dont upload many files. Plus if you use a CDR it may take longer to analyze the file. I guess it depends on the volume of files that you are trying to scan and the number of engines you use. Network hops may not be a factor in the latency.
    • g-ram_31429's avatar
      g-ram_31429
      Icon for Cirrus rankCirrus
