speks's avatar
speks
8 years ago
iCALL to trigger device failover ?
Hi Guys,
Wondering if I can use iCALL to trigger a device failover due to the failure of an F5 BGP Peer ?
  • Hi,
    Yes you can use ICALL to process a failover, but as you know you have to Triggered this call (reacting to a specific event).
    Can you tell me how you monitor your BGP peer? pool member monitoring, ....
    sys icall script failover {
        app-service none
        definition {
         tmsh::run /sys failover standby
    Regards
  • speks's avatar
    speks
    Really appreciate your comments folks - I will try out the suggestions and let you know how I get on...
