ICA Traffic and Kerberos
Hi, In a Citrix envieroment, where APM is publising the services:
1- Has all the traffic to pass through the APM ?? I mean, there are lan users, after the authentication with the APM, can these user connect directly to the xenapp/app server, in order to release some performance to the APM?? . 2- If Citrix support Kerberos, could APM support also Kerberos to avoid the user to authenticate
Thanks,
No, if you enable the ICA proxy bypass mode, then APM is just presenting the resources, and the users connect to the Xenapp/Xendesktop directly.
2 - re Kerberos - it's a much trickier animal - all depends on the Citrix versions and the required setup/scenario.
- Rul_74331Historic F5 Account
Thanks Michael,
For Kerberos integration, the are using Citrix XenApp 6.5 (and also 7.6) on Windows Server 2008 R2. They uses 3 types of Citrix services :Storefront, Web Interface and services based on ICA client, all of them are sopported??
The only reason you'd want to use APM internally is to replace StoreFront/WebInterface - else you do not need APM and can just load-balance StoreFront/WebInterface internally.
