iApp- Exchange 2010, Android Mobile Devices using Autodiscover and Active Sync Failing
I have all MS Exchange services working with one F5 VS/IP. I have just upgraded the Exchange iApp to v1.3.0 All external services work from laptops, iPhones and ipads except for some Android Mobile devices. Has anyone else had issues with Android devices when using Autodiscovery, Active SYNC?
- mikeshimkus_111Historic F5 Account
Hi Joe, this just started when you upgraded to v1.3.0? Which version of BIG-IP are you running?
thanks
Mike
- Joe_5599_134300
No it was happening during our testing on the v1.2 template last week. We are not yet live on the F5 and trying to UAT all before go-live. - mikeshimkus_111Historic F5 AccountOK. What are the specific issues? Here's a list of known issues from MS: http://support.microsoft.com/kb/2563324 I recommend opening a case with F5 Support and posting the case number here so I can track it and take a look at your config. They can also take some packet captures to try and discover what's going on.
- Aviv
Cirrus
I have problem connecting LG G3 (android 5.1)smartphone with exchange active sync. i have an exchange 2010 bigip ver 12 and iapp 1.51 and i'm using apm. the problem is the same with iapp 1.6. other android smartphones and also ios devices does not have problem . can some tell me why the problem is only on LG smartphone? how to investigate the problem?
