Nuruddin_Ahmed_'s avatar
Nuruddin_Ahmed_
Aug 01, 2016
i rule for traffic redirection
I need your help in writing on irule -
if the request is coming from x.x.x.x and y.y.y.y and z.z.z.z then go to pool A Else go to Virtual server B
Thanks.
  • Hi,
    You can use the following irule or an ltm policy (http traffic) :
        when CLIENT_ACCEPTED {
            if { [class match [IP::client_addr] POOL_A_IPS] } {
                pool pool_a
                virtual virtual_server_b
    POOL_A_IPS is a datagroup containing your IP addresses x.x.x.x, y.y.y.y and z.z.z.z
    • Yann_Desmarest's avatar
      Yann_Desmarest
      Icon for Cirrus rankCirrus
      You can also change the Event context for http traffic for example :
              pool pool_a
    • Nuruddin_Ahmed_'s avatar
      Nuruddin_Ahmed_
      Hi Yann,
      You have been great help for many of my queries. I would test this one and update if it works.
  • Hi,
                pool pool_a
    • Yann_Desmarest_'s avatar
      Yann_Desmarest_
              pool pool_a
      Nuruddin_Ahmed_
      Hi Yann,
