Rusty_Hale_8009's avatar
Rusty_Hale_8009
Jan 16, 2007
I need help converting old 4.X rules into new 9.X irules
I have three rules that use classes defined in them. The classes are already built. I just need to convert the syntax to V9. I would appreciate any help on this. I am on a short timeline or I would hammer it out. Thanks in advance.
1.
if (http_uri contains one of NCR_MO_HighRateURI or client_addr == one of NCR_MO_HighRateIP) {
use pool Alamo_http_MO_robotic
else {
use pool Alamo_MO_Http
2.
if (client_addr == one of HighRateIP_Exclude) {
use pool NCR_MO_HTTP
else if (http_uri contains one of NCR_MO_HighRateURI or client_addr == one of NCR_MO_HighRateIP) {
use pool NCR_MO_HTTP_HighRate
else {
3.
use pool NCR_MO_HTTPS_HighRate
else {
  • 1:
      if { ([matchclass [HTTP::uri] contains $::MCR_MO_HighRateURI]) ||
           ([matchclass [IP::client_addr] equals $::NCR_MO_HighRateIP]) } {
        pool Alamo_MO_Http
    2:
      if { [matchclass [IP::client_addr] equals $::HighRateIP_Exclude] } {
        pool NCR_MO_HTTP
      } elseif { ([matchclass [HTTP::uri] contains $::NCR_MO_HighRateURI]) ||
        pool NCR_MO_HTTP
    3:
        pool NCR_MO_HTTPS
    Note: these aren't tested so you might want to make sure I got all the class and pool names correct but this should give you something to start with.
    -Joe
