I am not able to connect VE on Web page using https://192.168.1.245
Hi
Today I downloaded and tried LTM VE 10.1.0 trial version.
Issue : I am not able to connect VE on Web page using https://192.168.1.245
Checks :
1) VE boots just fine in VM player, it gives me CLI login and password screen.
2) Ipconfig /all from my system shows below,
Ethernet adapter VMware Network Adapter VMnet8:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.174.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
IP Address. . . . . . . . . . . . : 192.168.88.1
3) Tried to renew the VM adapter ips but no luck.
4) Tried a number of times to open open new session on VM player : No help
5) Below are my system and VM player details,
-- VM Player version 5.0.1
-- Windows XP Version 2002, SP 3.
Please help me resolve this issue so as to learn via LTM VE.
Thanks /Regards
Sachin
- What_Lies_Bene1
Can you login to the CLI via Player and enter the following command please: 'ifconfig | more' - the IP address shown for eth0 is the one you need to connect to. Also note that whatever interface on your PC/laptop Player is tied to needs to be UP. - Sachin_126126
Hey Steve,
Thanks for the prompt response.
when checked the management ip: VE was taking my one of my broadband IP (via DHCP), and I could open GUI using this ip.
Later I changed the IP to its default 192.168.1.245. Now not able to login again..
Here are the Ipconfig /all from my system...
VMnet1
IP Address. . . . . . . . . . . . : 192.168.1.1
Ethernet adapter Local Area Connection 8:
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Eth
ernet NIC
Physical Address. . . . . . . . . : 00-E0-1C-3D-A2-CE
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 10.27.37.2
Subnet Mask . . . . . . . . . . . : 255.255.224.0
Default Gateway . . . . . . . . . : 10.27.32.1
DHCP Server . . . . . . . . . . . : 113.193.1.15
DNS Servers . . . . . . . . . . . : 113.193.0.148
113.193.1.14
Lease Obtained. . . . . . . . . . : Monday, February 11, 2013 7:51:37 PM
Lease Expires . . . . . . . . . . : Monday, February 11, 2013 9:51:37 PM
VMnet8
and
for ifconfg | more ::: How to copy ??
Thanks - Sachin_126126
Hey Steve,,
Able to open in GUI..
I just changed..
1) the Network Adapter 1 in VM player to Host-only Mode
2) Set the Network Adapter 2's IP to 192.168.1.1 255.255.255.0 and,
3) Disabled Network Adapter 3 (though it's not required)
Its working fine.
Thanks for your time..hope to talk to you again.TC
Resolving case... - What_Lies_Bene1
Great, you're welcome. Look forward to it. Cheers
