Dave_21507's avatar
Dave_21507
Oct 01, 2009
HTTP::uri starts_with - how to make it case insensitive?
Hello everyone,
I have the following iRule in place and it works great, but discovered that a "workaround" is using onlineusers.aspx or any other combination of case (e.g., OnLineUSerS.ASPx wouldn't redirect to login.aspx).
if { ( [HTTP::uri] starts_with "/OnlineUsers.aspx" )
and ( not [ matchclass [IP::client_addr] equals $::ips_irule ] ) }{
HTTP::redirect https://[HTTP::host]/login.aspx}}
Is there a way to modify it so it's not case sensitive?
Thanks!
  • hoolio's avatar
    hoolio
    You can set the URI to lower case before evaluating it:
    [string tolower [HTTP::uri]]
    Aaron
  • All set!!
    To help others, here is what I came up with (first I created a new data group for strings called allowed_uris and put /onlineusers.aspx in there):
    if { ( [matchclass [string tolower [HTTP::uri]] starts_with $::allowed_uris] )
    Thanks again
  • hoolio's avatar
    hoolio
    There is an issue with this in that someone could make a request to /doesnt_exist/../allowed_uri/whatever and that would bypass your rule logic and go to the default pool. The webserver would normalise the requested URI to /allowed_uri.
    You can check a recent post for more discussions on this:
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=30900&ptarget=30901
    Aaron
  • Ahh yes that's an interesting point you bring up. However, I'm not using this irule to direct users to different application pools. Using it simply to force people who are trying to access a certain page, and aren't coming from certain IP's to a login screen.
    I tested with http://hostname/doesnt_exist/../allowed_uri/whatever and it took me to the login page, so it is working as designed.
    Is there something I'm missing? If so, please let me know.
  • hoolio's avatar
    hoolio
    Are you trying to prevent certain clients from ever accessing specific URIs? If so, the iRule could be bypassed using obfuscation techniques.
    Aaron
