Joe_5599_134300's avatar
Joe_5599_134300
Jan 21, 2014
HTTPS VS inbound and :Port to Pool Selection
I't trying to get an inbound https VS working with an irule that will look at :port and send to the correct pool. If no port matched send reject.
https//:mytestlab.com:8080 https//:mytestlab.com:8081 https//:mytestlab.com:8082
I have been trying the below irule
when CLIENT_ACCEPTED {
switch [TCP::local_port] { "8080"{ pool mytestlabtest.com-8080 } "8081"{ pool mytestlabtest.com-8081 } "8082"{ pool mytestlabtest.com-8082 } default{ log local0.alert "[virtual name] [TCP::local_port] - No port match - TCP Reject" reject } } }
  • Might be easier to just setup a different VS for each one specifically listening on its individual port. Then assign pools appropriately.
    • Joe_5599_134300's avatar
      Joe_5599_134300
      I have done this before with a single Any Port 0 VS, now trying to get working with 443 VS doing the offload then send traffic to the correct pool by inspecting tcp port in request.
    • Cory_50405's avatar
      Cory_50405
      Icon for Noctilucent rankNoctilucent
      Understand, just thinking it would be simpler to use a virtual server for each port. Then there's no need for any iRules. It can certainly be done the way you are going.
  • James_Deucker_2's avatar
    James_Deucker_2
    Historic F5 Account
    This is almost never a good idea, as Cory stated you're much better off using multiple VS and attaching the pools appropriately. By default the LTM will drop traffic that doesn't match, you can do the reject if you really want by doing
    VS_8080 x.x.x.x:8080 -> type standard, pool mytestlabtest.com-8080
    VS_8081 x.x.x.x:8081 -> type standard, pool mytestlabtest.com-8081
    VS_8082 x.x.x.x:8082 -> type standard, pool mytestlabtest.com-8082
    VS_0 x.x.x.x:0 -> type reject
    That lets you put the appropriate profiles (like independent clientssl profiles) on each VS. It's more efficient than using an iRule and easier to read.
    If you want to log the rejects you would attach an iRule with a log statement to VS_0, or use a logging profile, or AVR.
    If you really, really want to do this with the port 0 VS and iRule then you can do it with a switch as you have above.
