solaikumar_1217's avatar
solaikumar_1217
Jan 12, 2016
HTTPS to HTTPS redirection using iRules
Dear All,
I have got one new requirement in LTM to forward the HTTPS/HTTP request to instead of or http://your-domain.com/. Have written iRule as follows .For HTTP request everything works fine , but HTTPS it is not(I feel some decryption required at F5 level). Please suggest.
Note : The main reason is that the user is getting Apache webpage when they access the root URI ,whereas actual resource is available at /xyz. I am also aware that there is an option at server level, but still looking for solution at HLB level.
Irule details :
if { ([HTTP::uri] == "/") or ([HTTP::uri] == "https://your-domain.com")} {
    HTTP::redirect https://your-domain.com/xyz/
else {HTTP::redirect "https://[HTTP::host][HTTP::uri]" } }
With Regards, Solaikumar.k
  • Hi Solaikumar,
    yes you would need Layer7 inspection for HTTPS-Traffic to parse the request headers and to perform the required redirects.
    Furthermore a
    [HTTP::uri]
    does only contain the
    [HTTP::path]
    [HTTP::query]
    part of the web request, but not the protocol used nor the host-header of the site. But based on your functional requirements it wouldn't be required to differentiate on those informations, since both protocols would require the same action.
    Scenario 1: Seperate iRule for HTTP and HTTPS Virtual Server
    iRule used for HTTP-only VS:
        HTTP::redirect "https://[getfield [HTTP::host] ":" 1][HTTP::uri]"
    iRule used for HTTPS-only VS:
        if { [HTTP::uri] equals "/") } {
             Forward the Request
    Scenario2: Combined iRule used for HTTP and HTTPS Virtual Server
        if { [PROFILE::exists clientssl] } then {
                 Forward the Request
    Note: Scenario 1 has a slightly better performance compared to Scenario2
    Cheers, Kai
