VijayKumarBC_25's avatar
VijayKumarBC_25
May 20, 2016
HTTPS to HTTP Redirection changes required
Below redirection iRule is working for - https://www.my.com
But Not working for https://my.com
Please suggest if there are any changes required
when HTTP_REQUEST { set HOST [string tolower [HTTP::host]] set URI [string tolower [HTTP::uri]]
 Start switch host
 switch -glob $HOST {
 "my.com" -  "www.my.com"
       HTTP::respond 301 Location "http://www.my.com"
  • when HTTP_REQUEST { set HOST [string tolower [HTTP::host]] set URI [string tolower [HTTP::uri]]
     Start switch host
     "my.it" -  "www.my.it"
           HTTP::respond 301 Location "http://www.my.it"
  • That rule should work fine. I suggest adding logging. In addition, is there more to the iRule? If not, I recommend strongly against setting
    $URI
    . In fact, it's sub-optimal to set
    $HOST
    as a variable, unless it is going to be used more than once. Normally, in programming, coding defensively and optimizing for readability and maintenance efficiency is sensible, but that's not the case with iRules. If one must choose between those things and performance, you almost always want to choose performance, since it executes with each connection (or, in the case of the rule below, each HTTP Request received). Finally, the use of
    -glob
    on the
    switch
    should be used only if you intend to perform glob matching. For strict matching, it's about 10% faster to exclude the
    -glob
    . Perhaps give this a try:
        switch [string tolower [HTTP::host]] {
        "my.com" -
        "www.my.com" {
            log local0. "Matched HTTP::host = [HTTP::host]"
    Look in
    /var/log/ltm
    for the log message. If it does not match when you are going to https://my.com, then try the following:
        log local0. "Host header = [string tolower [HTTP::host]]"
        "my.com" -
        "www.my.com" {
    and try the request, again looking in
    /var/log/ltm
    (be aware that, if the request rate is quite high, the log may be suppressed, and you may end up with a lot of logging!). Once you are done testing, don't forget to remove the logging statements, of course.
