HTTPS REDIRECTION : Specific NODE using iRULE
Hi Experts ,
i am working on one requirement where i need to redirect https://www.example.com needs to redirect to specific NODES ( 8 nos ) based on URI PATH .
i have created a layer 7 virtual server with SSL profile and attach it with following irule :
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/m2p/"}
node 10.30.214.1 2783
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/aps/"}
node 10.30.230.31 7001
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/bmx/"}
node 10.30.214.38 61648
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/cts/"}
node 10.30.214.236 4515
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/mii/"}
node 10.30.215.174 50000
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/ampla-bma/"}
node 10.30.222.43 8889
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/ampla-bmc/"}
node 10.38.2.48 8889
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/iqt-bma/"}
node 10.30.215.208 8889
return
if {[HTTP::host] contains "TEST-ESB-VIP-BMA.example.com" and [HTTP::path] eq "/iqt-bmc/"}
node 10.30.222.230 8889
return
when i try to access the VIP IP using its DNS name https://TEST-ESB-VIP-BMA.example.com/m2p as an example , BIG-IP is sending me RST back stating no Server selected . I can see hit on irule in the statistic TAB .
Here is the packet capture from the BIG-IP :
10.30.230.58.https > 10.139.153.195.53666: Flags [.], cksum 0x94c1 (incorrect -> 0x7121), ack 1352, win 5449, length 0 out slot1/tmm0 lis=/Common/VS_MULE_BMA_TEST_HTTPS_443 flowtype=64 flowid=560000E1C600 peerid=0 conflags=4000024 inslot=63 inport=23 haunit=1 priority=3 peerremote=00000000:00000000:00000000:00000000 peerlocal=00000000:00000000:00000000:00000000 remoteport=0 localport=0 proto=0 vlan=0
02:14:04.293589 00:50:56:ba:17:86 > 54:7f:ee:09:d8:c1, ethertype 802.1Q (0x8100), length 176: vlan 2200, p 0, ethertype IPv4, (tos 0x0, ttl 255, id 44631, offset 0, flags [DF], proto TCP (6), length 40)
02:14:04.293640 00:50:56:ba:17:86 > 54:7f:ee:09:d8:c1, ethertype 802.1Q (0x8100), length 246: vlan 2200, p 0, ethertype IPv4, (tos 0x0, ttl 255, id 44633, offset 0, flags [DF], proto TCP (6), length 83)
10.30.230.58.https > 10.139.153.195.53666: Flags [R.], cksum 0x94ec (incorrect -> 0xc3d1), seq 148:191, ack 1352, win 0, length 43 [RST+ BIG-IP: [0x29b630c:4504] No se] out slot1/tmm0 lis=/Common/VS_MULE_BMA_TEST_HTTPS_443 flowtype=64 flowid=560000E1C600 peerid=0 conflags=4800024 inslot=63 inport=23 haunit=1 priority=3 rst_cause="[0x29b630c:4504] No server selected" peerremote=00000000:00000000:00000000:00000000 peerlocal=00000000:00000000:00000000:00000000 remoteport=0 localport=0 proto=0 vlan=0
I am NOT sure what i am doing wrong here .If anyone can guide me what i am doing wrong will be much appreciated .
Thanks in advance .
- Deepak_Nair
Cirrus
Thanks Kees and All for helping me OUT on this . Much appreciated .
- Deepak_Nair
Cirrus
Ok , i ran into problem . The iRULE work fine but the requirement is to replace the host header from test-esb-vip-bma.example.com/m2p to a new url "www.newurl.com/m2p when the LB initiate the request to the server end .
what is mean to say is for example as per the irule /m2p is pointing to node 10.30.214.1 2783 . So when the LB initiate the HTTP Get request , it rebuilt the URL with new HOST 10.30.214.1 with URI /m2p . Is this achievable ?
the scenario is as below
from CLIENT_TO_LB ---> https://test-esb-vip-bma.bhp.com/m2p
from LB_To_SERVER. ----> http://10.30.214.1:2783/m2p
I am trying to TWEAK my irule . Any help in this regard how to replace the HOST header when the LB initiate the request and change with NODE IP AND PORT and append the URI ?
- Deepak_Nair
Cirrus
This URL test-esb-vip-bma.example.com should only be visible to CLIENT and URL header replacement shouldn't be visible to CLIENT .
- Deepak_Nair
Cirrus
i Wrote a sample to see if this work .
if {([string tolower [HTTP::host]] equals "test-esb-vip-bma.bhp.com") &&
[HTTP::uri] starts_with "/cts" }
HTTP::header replace "Host" "10.30.230.15:4515"
HTTP::uri
The Irule is hitting BUT connection is getting RESET .
But now the BIG-IP doesn't know where to send the request...
when HTTP_REQUEST { if {([string tolower [HTTP::host]] equals "test-esb-vip-bma.bhp.com") && [HTTP::uri] starts_with "/cts" } { HTTP::header replace "Host" "10.30.230.15:4515" node 10.30.230.15 4515 } }Sorry for the formatting..... Can you try the above irule?
Cheers,
Kees
- Deepak_Nair
Cirrus
Hi Kees ,
This works !!! thanks alot .
Sorry for my trouble Question again !
The actual URI PATH is HP01/CtsConsignment?wsdl . SO with the ABOVE iRULE the actual URL && URI PATH it take is 10.30.230.15:4515/cts/HP01/CtsConsignment?wsdl .
BUT there is no resource exist in cts/HP01/CtsConsignment?wsdl . The Resource actually exist in URI HP01/CtsConsignment?wsdl .
So i want to STRIP OUT /cts from the URI path once the Host Header is replaced with 10.30.230.15:4515 .
In summary when client request to LB with https://est-esb-vip-bma.bhp.com/cts and request accepted
then LB rebuild the URL with http://10.30.230.15:4515//HP01/CtsConsignment?wsdl
Can this be achieved using irule or i should ask application team to create a URi PATH with cts/HP01/CtsConsignment?wsdl on the server .
Thanks .
Hi Deepak,
I think you need an irule development course 😉
Is the only uri behind /cts/ /hp01/ctsconsigment?wsdl or are the more?
Cheers,
Kees
- Deepak_Nair
Cirrus
Hi Kees ,
I am currently Working towards to get friendly with IRULES . Really sorry for hitting with many question . My bad 😐
There are like 200 URLS served from different HOSTS ( around 8 or 9 in nos ) . we want to ROUTE the application based on URI PATH which we discussed with ABOVE iRULE .
So for example , when client comes with https://est-esb-vip-bma.bhp.com/cts it should go to http://10.30.230.15:4515/HP01/CtsConsignment?wsdl or some other URI based on data they NEED . Here with VIP IP and URI PATH , IRULE we defined selects the desired HOSTS .
if client comes with https://est-esb-vip-bma.bhp.com/m2p it should route to http://10.30.215.16/Integration1.0/MaterialsServices.svc etc etc
So in general , i want to STRIP OUT the first URI in request and APPEND REST to the selected NODE within the iRULE .
I am doing some reading BUT not sure if this is achievable via IRULE . So reaching out for help from experts .
If NOT achievable then i will ask the APPS team to locate the content BUILD during HHTP get request from F5 based on iRULE .
Thanks /
Hi Deepak,
It is ok, that is what devcentral is also for. To help.
Ok, so you need code to strip off a part of the uri.
Use this:
when HTTP_REQUEST { if {([string tolower [HTTP::host]] equals "test-esb-vip-bma.bhp.com") && [HTTP::uri] starts_with "/cts" } { HTTP::header replace "Host" "10.30.230.15:4515" HTTP::uri [string map [list "/cts" "" ] [HTTP::uri]] node 10.30.230.15 4515 } }- Deepak_Nair
Cirrus
Thanks Kees . This Works .
Thanks Alot for helping me OUT . Much Appreciated .
I really need some irule development course .
Your welcome Deepak!
