HTTPS Monitor not working as expected
I'm having trouble with a HTTPS monitor and was after some advice. The monitor is configured as follows:
monitor ars-status-https { defaults from https recv "ServiceUp" send "GET /status.htm HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\n" }
however it's marking the pool members as down. If I browse to that URL I get the expected response which contains "ServiceUp" string. And if I test from the CLI of the LTM I also see the expected response, for example using curl:
time curl -k
ÿþhttp://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
ServiceUp
real 0m0.033s user 0m0.016s sys 0m0.008s
So any ideas on why this might be failing? Or suggestions on troubleshooting it further? For now we have got the nodes marked as up using the default iis start page on the health check instead but want to get this working on the service status page.
thanks
Andy
- What_Lies_Bene1
You have specified the Host: header in your send string but left it blank; I don't think a blank value is valid in HTTP/1.1.
Have you tried using the
command to test from the CLI?[tmsh] run util test-monitorAlso, use
and see if curl is providing a Host: value.curl -v - andrew_deackes_
so with curl -v I can see the host value is provided, see this snippet:
> GET /status.htm HTTP/1.1 > User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5 > Host: XXXXXXXXX > Accept: */* > < HTTP/1.1 200 OK < Content-Type: text/html < Last-Modified: Thu, 23 Apr 2015 10:32:09 GMT < Accept-Ranges: bytes < ETag: "16a183c0b07dd01:0" < Server: Microsoft-IIS/8.5 < X-Powered-By: ASP.NET < Date: Thu, 23 Apr 2015 10:32:19 GMT < Content-Length: 508I can't use the tmsh command as we are currently still on a 10.24 release. Command looks useful though and should come in handy once we get upgraded later this year.
thanks
Andy
- What_Lies_Bene1
OK, cool. So I assume you'll add it to your send string and all will be well?
- andrew_deackes_
so I've tried specifying the host field in the monitor and no joy. Also treid removing host from the send string and just sending the get:
GET /status.htm
and again no change, still marked as down. :-(
- nitass
Employee
can you try tcpdump?
start tcpdump before assigning monitor to pool. also, you need server's private key to decrypt tcpdump output file.
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x and host y.y.y.y and port zzz -v x.x.x.x is non-floating selfip on pool member vlan y.y.y.y is pool member ip zzz is pool member port - andrew_deackes_
thanks all, issue was down to bad formatting on the status page, had extraneous full stops:
.<.h.e.a.d.>. . .<.t.i.t.l.e.>.H.T.M.L. .T.A.B.L.E.<./.t.i.t.l.e.>. . .<./.h.e.a.d.>.<.b.o.d.y.>. . .S.e.r.v.i.c.e.U.p. . .<.t.a.b.l.e.>. . .<./.t.a.b.l.e.>. . .<./.b.o.d.y.>.<./.h.t.m.l.>.
once the web team fixed that it is working perfectly.
cheers
