https monitor failing on receive string
Dear Folks,
I am trying to setup an https monitor where we have the send and receive string, when debugging the output using curl, this is the output
< HTTP/1.1 302 Found < Date: Tue, 15 Nov 2016 21:42:33 GMT < Server: Oracle-HTTP-Server-11g < Set-Cookie: OAMAuthnHintCookie=0@1479246153; httponly; secure; path=/; domain=.39.xx < Set-Cookie: OAMRequestContext_10.1.xx.xx:7787_636955=ciUK05ji8Qknb5+cXIq4Ng==;max-age=300; httponly; secure; path=/ < Location: http://taxap.internal.xyz.com:14100/oam/server/obrareq.cgi?encquery%3DKPByGkU9KLBSD5H1HJlzqtSbDnItoYPgXasC2r4o%2B7AaABNDFXn24eKXASBAqR%2FWZXYN4qhUCFNrrjType1TN11%2B2%2FEL3MIkTEd6C%2BhT4r3JUKHe14CDvpVlL3Rx1ip3JtFeNlHu9hMiufirSmK2yzZXImzcBE5%2F5DYBoyijrgtfG92HQEKduHcHIqdwUW02sBMNBj05gGQSpIUi%2FcSo0lolua7KKFPKCDag4bmhSt%2BSgGYfOsUIVUE1dcjAbKXS2El50UbINjAb36q4G1R8UENvJzzG1ZXRyEvCKCxWZNAOcFT4P1aJmmRZS8MQxtlr1RYb3IYFoHM2hKkI0Hltzw%3D%3D%20agentid%3Dstg2_agent_lsa02%20ver%3D1%20crmethod%3D2&ECID-Context=1.005GLrLV6%5EyCgo1_zt%5EAyW0001Xx0000%5EN%3BkXjE < Content-Length: 783 < Content-Type: text/html; charset=iso-8859-1 < //DTD HTML 2.0; 302 Found
Found
The requested resource has been temporarily moved here.
* Connection 0 to host 10.1.xx.xx left intact * Closing connection 0 * SSLv3, TLS alert, Client hello (1):
But when I try to access the string directly from the server, I get the required string https://taxap.internal.xyz.com:7787 GET string: /public/HealthCheck.htm Receive String: Welcome!
I don't know why the difference is. Can somebody help, Every time I put the receive string the monitor, the monitor fails.
- David_Stout
Does your send string look something like this and include the Host header ?
GET /public/HealthCheck.htm HTTP/1.1\r\nHost: taxap.internal.xyz.com\r\n\r\nFrom what's listed above it looks like the F5 is calling the site by it's IP address and not it's actual hostname so it would give a different result than a browser.
- stan_piron
Cumulonimbus
In your curl response, there is no "Welcome" string.
so, the monitor result is correct.
can you try with following curl command:
curl -k -v https://taxap.internal.xyz.com:7787/public/HealthCheck.htm --resolve taxap.internal.xyz.com:7787:10.1.39.xxon F5 curl command does not support --resolve. you must use curl-apd instead of curl:
curl-apd -k -v https://taxap.internal.xyz.com:7787/public/HealthCheck.htm --resolve taxap.internal.xyz.com:7787:10.1.39.xxif it works, the monitor must be:
GET /public/HealthCheck.htm HTTP/1.1\r\nHost: taxap.internal.xyz.com:7787\r\n\r\n - ekaleido
Cirrus
The response is coming from the server, not the F5. So when you get a 302 and there is no mention anywhere of "Welcome!" the health check will fail because the Receive String is not being matched.
Perhaps your send string should actually check against the URI you are being redirected to?
Okay Sorry, I am not sure if I understand this.
The "https" monitor is set to receive the "Welcome!" String from the Server and both the servers in the Pool when accessed directly gives me that string but F5 is not.
- ekaleido
Cirrus
No. When you go direct to the server you get a 302 redirect from the server, as evidenced by the curl output above. But as an end user you do not see that, you just see a page render that says "Welcome!"
But what really happens is the response (and where the receive string will be judged) is a 302 redirect. That is where you would have to match the "Welcome!" string.
Does that clear it up for you?
- ekaleido_26616
Cirrocumulus
- ekaleido_26616
Cirrocumulus
