Shamsul_Alam_34's avatar
Shamsul_Alam_34
Dec 12, 2017
Https 404 error
Hi expert,
Currently I'm having an issue with my web server (IIS) node on my F5 LTM. I created one node with hostname as below Hostname: CRM-WEB-01
On my IIS i bind the website/portal with hostname as abc.org
Note: IIS server hostname is CRM-WEB-01
When i try to access the website through F5 it give me error 404. I need help to identify why I'm getting error 404 (HTTP Error 404. The requested resource is not found.)
  • From the client machine, use curl command to see the response or from the browser, you can try and use the developer tools to check the response. It may give some clues to solve the problem.
