Todd_Jones_1074's avatar
Todd_Jones_1074
Sep 18, 2012
HTTP::redirect cause reset
Hello,
I've been given a requirement to ensure that a URI is passed to the web servers with the correct case. For example:
www.host.com/CASEmatters is correct
www.host.com/casematter or /CaSeMaTtErS need to be redirected to /CASEmatters.
I've tried HTTP::redirect, HTTP::uri and HTTP::respond. All of them result in a reset instead of a redirect.
Here is my iRule with the redirect. Any help you can provide will be appreciated.
switch -glob [string tolower [HTTP::uri]] {
"/foo*" { pool foo }
"/bar*" { pool bar }
"/casematters*" {
switch -glob [HTTP::uri] {
Check URI for match to desired case "CASEmatters"
"/CASEmatters*" { pool casematters }
If it doesn't match then redirect
default { HTTP::redirect "https://[HTTP::host]/CASEmatters" }
default { pool default }
  • I'd skip the nested switch evaluation and just trigger the casematters code if the [string tower [HTTP::uri] equals "/casematters". Also, assuming you don't need the client to actually see the different case in the address bar, just change the HTTP::uri on ingress.
            "/foo*" {
    log local0. "foo pool"
    pool foo
            "/bar*" {
    log local0. "bar pool"
    pool bar
            "/casematters*" {
    log local0. "casematters pool"
                    pool casematters
    set sub_uri [findstr [string tolower [HTTP::uri]] "/casematters" 12]
    log local0. "sub_uri = $sub_uri"
                    HTTP::uri "/CASEmatters$sub_uri"
  • No runtime error in the logs.
    @Kevin Stewart - your suggestion worked! Thank you. I'm still curious why the reset but now my client will be happy :-)
