gamm_31377's avatar
gamm_31377
May 27, 2014
HTTP::payload replacement
Hello,
I try to modify a HTTP SOAP request from a client, because the used namespace is not correct (:i -> :xsi). The iRule is assigned to the virtual server. The replacement is correct, but when the ASM module is validating the XML it fails because the SOAP Request is to short.
I think the replacement of the payload does not work in the way I expect: HTTP::payload replace 0 [string length $newdata_1] $newdata_1
How can I exchange the payload against a larger buffer ?
Best Regards Jürgen
iRule to modify a SOAP request from a client
when RULE_INIT { set static::debug 1 }
when HTTP_REQUEST { Get the Content-Length Content-Length is only part of an POST, a GET has no Content_Length attribut
if Content-Length is > 1MB then set Content-Length to 1MB
if { [HTTP::header exists "Content-Length"] } { set content_length [HTTP::header "Content-Length"] } else { set content_length 0 } if { $content_length > 0 && $content_length < 1048577 } { set collect_length $content_length } else { set collect_length 1048576 }
if { $collect_length > 0 } { content_length != 0 if HTTP::collect was executed next step is the event HTTP_REQUEST_DATA HTTP::collect $collect_length } }
when HTTP_REQUEST_DATA {
if {$static::debug}{log local0. "payload before: [HTTP::payload $collect_length]"}
regsub -all ":i" [HTTP::payload] ":xsi" newdata_1
if {$static::debug}{log local0. "length newdata_1 : [string length $newdata_1]"}
replace the old payload with the new HTTP::payload replace 0 [string length $newdata_1] $newdata_1
if {$static::debug}{log local0. "payload after: $newdata_1"}
HTTP::release }
  • can you try this?
       HTTP::payload replace 0 [string length [HTTP::payload]] ""
       HTTP::payload replace 0 0 $newdata_1
  • can you try this?
  • You should actually be able to get away with using a STREAM profile here. It'll be much faster than buffering request payload and you can also get rid of the regex.
        if { [HTTP::header Content-Type] contains "soap" } {
            STREAM::expression {@:i@:xsi@}
            STREAM::enable
            STREAM::disable
    when HTTP_RESPONSE {
        STREAM::disable
    One important caveat of using STREAM in an HTTP_REQUEST is that you need to force HTTP chunking. Create a new HTTP profile and set Request Chunking to "Rechunk". Add this HTTP profile and a generic empty STREAM profile to the VIP, along with this iRule.
  • It was not the length I got the following error:
    XML Buffer N/A Description Malformed document Document has no root element Context URL XML Profile XML_OSMCService
    POST /axis/services/OSMCService HTTP/1.1 User-Agent: kSOAP/2.0 SOAPAction: getGeneralInfoCollection Content-Type: text/xml Connection: close Host: 172.30.245.13 Accept-Encoding: gzip
    and the HTTP_REQUEST looks well formed:
    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
  • Hello,
    how about if the payload is more than 1MB? in my case I need to replace let's say first and last lines in the request message...it's doing it for the first line but not for the last line ( I guess because it's only collecting 1MB of the message which miss out the last line)..any idea? thank you in advance.
