HTTP::path -normalized (TMOS 13) issue?
According to the Wiki,
HTTP::path -normalized should do:
the normalization involves lower-casing, removing unnecessary directory traversals, convert from microsoft style %uxxxx form to the standard %xx hex form, bytes not allowed in a uri are normalised to their percent-encoded representation, bytes percent-encoded when they don't need to be are changed to their normal representation
My experience (TMOS 13.1) is that:
- conversion to lower case does not work at all!
is converted to"%2E%2E"
(OK)".."
is converted to"/foo/../bar"
(OK)"/bar"
However (FAIL):
is (only) converted to"/foo/%2E%2E/bar"
."/foo/../bar"
It seems that directory traversal normalization is (incorrectly) performed before %-normalization. I would expect to first do %-normalization and then normalize directory traversal...
So, in order to perform normalization correctly, I need to do this (I need to retain the original URI in the request to the pool member):
set origPath [HTTP::path]
set normPath [string tolower [HTTP::path -normalized]]
HTTP::path $normPath
set normPath [HTTP::path -normalized]
HTTP::path $origPath
log local0. "Path : \"$origPath\" --> \"$normPath\""
I would have expected to do this, though:
log local0. "Path : \"[HTTP::path]\" --> \"$normPath\""
Is there a more elegant way to perform normalization on the URI/PATH?
And can this be fixed, please?
- JG
Cumulonimbus
Apparently the system goes through one pass only, and 2 passes seem to be good enough for your situation.
It would be better for the system to use a loop, and break out if the output is equal to the input.
You might want to open a support case so that F5 developers are aware of this issue.
- Simon_Blakely
Employee
As an addendum to the response from Jie
The canonical word on the operations of normalize are
1) The case of scheme is normalized to lower-case.
2) The hostname is normalized to lower-case. A possible trailing '.' is removed from the hostname.
3) IP addresses are normalized. There are many ways to write an IP address (v4 and v6). These are cannonicalized to a normal form.
4) Ports are normalized. Unnecessary port annotations (like :80 on a http request) are removed.
5) Paths are normalized, with extra unneeded directory traversals removed.
6) Percent-encoding normalization. Bytes not allowed in a uri are normalized to their percent-encoded representation. Bytes percent-encoded when they don't need to be are changed to their normal representation. We convert from microsoft style %uxxxx form to the standard %xx hex form.
7) Fragment specifiers are removed.So - HTTP::uri/HTTP::path -normalize should not change the case of a URI.
The documentation for HTTP::uri is probably clearer.
- Frank_30530
Altocumulus
I got confirmation by F5 support that lower-casing is not intended (and not performed) and the Wiki documentation (HTTP::path -normalize) is in error.
I also got a bug-id concerning the order of "directory traversal normalization" and "%-normalization.":
bug ID708068 (HTTP: normalize directory traversal after percent-encoding)
I have requested to add this to the known issues section of the Wiki (HTTP::path).
- JG
Cumulonimbus
Thanks for reporting back.
