Rich_VA's avatar
Rich_VA
May 02, 2019
httpd settings keep re-enabling
HTTPD settings keep re-enabling.
Was testing out settings for the management UI login.
I end up having to go into tmsh or vi to un-do them. (Per the documentation.) (ssl-client-verify and ssl-ocsp-enable)
I save a /sys config after I un-do the setting however every time I sync the Active and Standby the settings come back and re-enable.
Are those settings stored in another file somewhere that the sync process reads?
