Jon_Gilyeat_149's avatar
Jon_Gilyeat_149
Jul 24, 2014
HTTP::cookie and setting flags
I'm struggling with writing some irule logic which sets the httponly and secure flags on only the bigipserver cookies inserted by the F5 when using cookie session persistence, while not affecting any server or application inserted cookies. So far, I've had to resolve myself to creating a different irule for each VIP for which I need to perform this action, and specifying the bigip server cookie for that VIP, eg:
when HTTP_RESPONSE {
  if { [HTTP::cookie BIGipServerFoo] ne "" } {
    set ck_value [HTTP::cookie value BIGipServerFoo]
    set ck_path [HTTP::cookie path BIGipServerFoo]
    HTTP::cookie remove BIGipServerFoo
    HTTP::cookie insert name BIGipServerFoo value $ck_value path $ck_path version 1
    HTTP::cookie httponly BIGipServerFoo enable
    HTTP::cookie secure BIGipServerFoo enable
BigIP server cookie flags are set appropriately, application cookies are left alone, everyone is happy, apps don't break. Surely there must be some way to do this without manually picking out the cookies I want changed.
  • Tried this and it doesn't really work either:
      if { [HTTP::cookie starts_with "BIGipServer"] } {
         set ck_names [HTTP::cookie names]
         foreach aCookie $ck_names {
         HTTP::cookie remove $aCookie
         HTTP::cookie insert name $aCookie value $aCookie path / version 1
         HTTP::cookie httponly $aCookie enable
  •  when HTTP_RESPONSE {
         foreach ck_name $ck_names {
            if { [string tolower $ck_name] starts_with "bigipserver" } {
                set ck_value [HTTP::cookie value $ck_name]
                set ck_path [HTTP::cookie path $ck_name]
                HTTP::cookie remove $ck_name
                HTTP::cookie insert name $ck_name value $ck_value path $ck_path version 1
                HTTP::cookie httponly $ck_name enable
  • We have an ASM module, but we've not deployed it yet.
    After spending some time beating on it a bit more, I've managed to sort it out:
       set ck [HTTP::header values "Set-Cookie"]
       foreach acookie $ck {
          if {$acookie starts_with "BIGipServer"} {
             HTTP::header replace "Set-Cookie" "${acookie}; HttpOnly"
