Piotr_Lewandows's avatar
Piotr_Lewandows
Jul 05, 2017
HTTP to FTP conversion
TMG has feature to allow HTTP protocol on client side and internally convert it to FTP on server side. I wonder if it is possible to recreate such feature on BIG-IP - using for example iRule?
Piotr
  • I don't think you can do that with the same virtual server. You could do with different virtual servers, and have an iRule to switch between them.
    However, you would need to convert HTTP request to an FTP command, and that part would be definitely complicated.
    So, my conclusion is that you can't do.
