samo's avatar
samo
Jul 11, 2019
HTTP redirect when Path is / and host is not FQDN
I wrote a simple irule to do HTTP redirect:
  if { !([string tolower [HTTP::host]] ends_with "mycompany.com") } { append [HTTP::host] "mycompany.com" }
  if { [HTTP::path] eq "/" or [HTTP::path] eq "" } {
  HTTP::redirect "http://application.mycompany.com/ABC"
I expect my iRule to redirect:
http://application/ or http://application.mycompany.com/
to
But it is not the case, the iRule is not doing anything when host is not FQDN and it seems the condition evaluation doesn't work for empty path (/)
  • Hi,
    There are some possibilities to get this working.
    e.g.
        set host [getfield [HTTP::host] : 1]
        if { not ( [string tolower $host] ends_with "mycompany.com" ) } {
            append host ".mycompany.com"
            if { [HTTP::path] ne "/" } {
                HTTP::redirect "http://$host[HTTP::uri]"
        if { [HTTP::path] eq "/" } {
            HTTP::redirect "http://$host/ABC"
    Test #1:
     # curl-apd -v --resolve application:80:172.30.30.100 http://application
    * Added application:80:172.30.30.100 to DNS cache
    * Rebuilt URL to: http://application/
    * Hostname application was found in DNS cache
    *  Trying 172.30.30.100...
    * Connected to application (172.30.30.100) port 80 (#0)
    > GET / HTTP/1.1
    > Host: application
    > User-Agent: curl/7.47.1
    > Accept: */*
    * HTTP 1.0, assume close after body
    < HTTP/1.0 302 Moved Temporarily
    < Location: http://application.mycompany.com/ABC
    < Server: FRONTEND
    * HTTP/1.0 connection set to keep alive!
    < Connection: Keep-Alive
    < Content-Length: 0
    * Connection #0 to host application left intact
    Test #2:
    # curl-apd -v --resolve application:80:172.30.30.100 http://application/mypath
    > GET /mypath HTTP/1.1
    > Host: application
    > Accept: */*
    < Location: http://application.mycompany.com/mypath
    < Server: FRONTEND
    < Content-Length: 0
    Test #3:
    # curl-apd -v --resolve application.mycompany.com:80:172.30.30.100 http://application.mycompany.com
    * Added application.mycompany.com:80:172.30.30.100 to DNS cache
    * Rebuilt URL to: http://application.mycompany.com/
    * Hostname application.mycompany.com was found in DNS cache
    * Connected to application.mycompany.com (172.30.30.100) port 80 (#0)
    > GET / HTTP/1.1
    > Host: application.mycompany.com
    > Accept: */*
    < Server: FRONTEND
    < Content-Length: 0
    * Connection #0 to host application.mycompany.com left intact
    I hope it helps.
    Regards
