Joe_Pipitone's avatar
Joe_Pipitone
Nov 16, 2009
HTTP Redirect using switch issue
The following iRule isn't redirecting properly - these are supposed to be going to 4 separate URIs.
I moved over to a switch statement because I was getting a similar behavior - it's as if it is catching the /lv2010/es* first. I have tried removing the asterisks, but that did not work.
Can anyone help?
     switch -glob [string tolower [HTTP::uri]] {
      "/lv2010/es/register*" {
        HTTP::redirect "http://ourdomain.org/registration.aspx"
      "/lv2010/es/hotel*" {
        HTTP::redirect "http://ourdomain.org/hotel-and-travel.aspx"
      "/lv2010/es/qualify*" {
        HTTP::redirect "http://ourdomain.org/qualification.aspx"
      "/lv2010/es*" {
        HTTP::redirect "http://ourdomain.org/home.aspx"
      "/lv2010*" {
  • It appears as though the problem was the asterisk following /lv2010*. I've taken this out, and the other rules work.
    This poses the problem - if someone types in http://ourdomain.org/lv2010/ WITH the forward slash, the redirect does not work.
    Is there any way around this? If I put the asterisk in there, both with and without the slash work, however it breaks the other 4 redirects.
    Thanks for any help.
