HTTP Monitoring pool some times problem
Dear guys
at the moment , i have LTM , make virtual server to pool server (production server ) , i have monitoring pool server http monitor
GET /ipc/vi/ HTTP/1.1\r\nHost: <hostname>\r\nConnection: Close\r\n\r\n
Receive string: HTTP/1.1 200 OK ,
before it well working , but close day F5 alter pool down about 1 minute
Pool /Common/serverweb_80_pool member /Common/10.0.41.9:7727 monitor status down. [ /Common/Monitor_serverweb: down; last error: /Common/Monitor_serverweb: Response Code: 200 (OK) @2019/09/18 05:16:46. ] [ was up for 23hrs:58mins:29sec ]
pls help me check it
many thanks
- youssef1
Cumulonimbus
Hi
can you tell me configuration that you set in your monitor:
Interval: ?
timeout: ?
regards
- Hungpm
Thanks for your see and reply .
Interval 5 seconds
timeout 16 seconds
thanks
- youssef1
Cumulonimbus
In this case maybe the problem come from your application who do not respond correctly to the monitor's request during a lapse of time.
In order to validate this possibility you can enable "Monitor Logging":
https://support.f5.com/csp/article/K12531
to enable monitoring logging go in the pool then click on the poolmemeber, you will then have the possibility to activate this feature.
The BIG-IP system generates the following log file for the pool member:
/var/log/monitors/....
you could check the logs and see why your Backend server was down. by controlling the response of the server ...
keep me in touch if you need more details.
regards,
