chizow_71007's avatar
chizow_71007
Apr 09, 2009
HTTP Monitor on High Port
I cannot figure out how to configure a http monitor to work on a random high port. The reals are failing health checks. When I do a "tcpdump port 9006" on the server I see no traffic. Here is my config:
 virtual MY-VIRTUAL {
    snat automap
    pool MY-POOL-9006
    destination 10.120.228.96:http
    ip protocol tcp
    profiles
       http
       tcp
 pool MY-POOL-9006 {
    monitor all MY-MONITOR
    members
       10.120.11.200:9006
       10.120.11.205:9006
 monitor MY-MONITOR {
    defaults from http
    dest *:9006
A "telnet 10.120.11.200 9006" followed by a "GET /" works just fine.
  • Glad you found out what the problem was, but just FYI you don't have to specify a custom monitor on port 9006 if you've defined the pool members as 9006 already. The default http monitor will use whatever port the pool members are configured on.
    Where that comes in handy is if you have pool members defined on port 0 (wildcard). Then the monitor needs to specify a port.
    Denny
