Clint_16698
Aug 15, 2012HTTP Monitor Help
Disregard this since I could not display any xml elements that I need to look for in my http monitor.
- hoolio
Hi Clint,
Do you still have a questions? If you're having issues with rendering of the post, you can use [ code ] [/ code ] blocks (without the spacing) to post the info.
Aaron - Clint_16698
I thought I was having an issue with capturing the xml in the receive string, but it turned out (with a tcpdump) that I had too many back slashes in my send string, and I was getting a HTTP 400 back.
Thanks!
